Rad Rover 6+ Rear Brake Failure
Started by Ricsel, May 20, 2024, 10:44:02 AM
Ricsel
Was out riding today and suddenly realized I had no rear brake. How do I correct?
ARM
Start by replacing the brake pads - they wear out and the brake lever goes all the way in when you squeeze it.
Ricsel
Scheduled mobile service with Velofix and Dan determined that both front and rear brake pads were worn out. Replaced pads for front wheel and all is well, however the rear brakes were so worn the piston was damaged so have had to order replacement rear brake assemble from Rad. They have parts in stock now just waiting for parts to ship...
Ricsel
Received Rear Brake Assembly from Rad. Dan from Velofix returned and replaced rear brakes, all is 100%. Thanks Dan...
How much miles/km have you done before you started having brakes problems? I know everyone's riding is different but I am interested how long(km) your brake pads lasted.
on my rover 5 i would adjust them a few times a year.  i have replaced them 2 times and have about 6000 miles on it.
my other bike is a different make but it has hydraulic brakes.  I have 2600 miles on it.  I don't have to adjust them which is really nice, but the pads will need to be replaced probably by the time I get to 3000 miles.
so my hydraulic brake pads are lasting longer than the manual Rover brakes.
Jbator
Hello, I had my RR6+ serviced by Veloflix as well, they did a great job but after this service I began to have motor power cutting out. I've traced it back to the rear brake lever, when it's unplugged it runs perfectly but when the sensor is connected it faults intermittently, is there a way to adjust this or just replace the brake lever?
Quote from: Jbator on July 24, 2024, 08:41:45 PMHello, I had my RR6+ serviced by Veloflix as well, they did a great job but after this service I began to have motor power cutting out. I've traced it back to the rear brake lever, when it's unplugged it runs perfectly but when the sensor is connected it faults intermittently, is there a way to adjust this or just replace the brake lever?
It could be the brake sensor or it may be the controller.  The good thing is you can use the bike with the rear brake wiring unplugged.  Most of the braking power is from the front brake and it will cut the motor off when applied.
Try swapping the front and rear wiring and see if it acts the same.  If it does then it is the controller.  If not then it is the brake level sensor.
