Rad 5 plus Electro World 35 Amp Upgrade Install Question
Started by Jay West, June 05, 2023, 02:31:01 PM
Jay West
I received my Electro World 35 Upgrade kit and I was wondering if anyone had installed this on Rad City 5 Plus ST. The question I have is how did you mount the controller? The space between the seat tube and the fender is not wide enough to accommodate the thickness of the controller. It looks like I would have to put a spacer between the fender and the frame to move it backward a 1/2" or so to fit the controller box between the seat tube and the fender.
I would appreciate it if someone had installed this controller would give me an idea how they did it.
Thanks
Jay
Jay West
I don't have any pics.  There just isn't enough room between the seat post and the fender to install the controller without making some alterations like moving the fender rearward. The controller is too thick to fit the space.   I was looking for someone who had made this install so I could get some ideas before I began the install on my Rad City 5 +.
Thanks
Jay
My Radmission seems to have the same geometry, although the OEM controller on the Radcity 5 looks incredibly small in photos. I chose the 25-amp controller so it would fit. It will provide 70% as much power, which is still much better than OEM for my 500 watt Radmission or my 750 watt Radrunner. For a nonslip surface, I applied RTV to the seat tube and let it cure. Then I secured the controller with 120-lb zip ties.
If you stick with the 35-amp controller, it looks as if a Radcity 5 has room to strap it in front of the seat tube.
Looks like the two most viable options are on the front of the seat tube (will interfere with the step through function a bit), or under the rear rack (will need cable extensions except for the taillight. You can go with the 25 amp controller to place it between the seat tube and the rear fender, and it will greatly improve power, but you'll lose a bit of efficiency.
cssshb
Quote from: Jay West on June 10, 2023, 03:28:21 PM
Thanks
Jay
Did you manage to get the 35a controller installed on your RadCity 5+ Step-Thru?
I have ordered the 35a controller for my RadCity 5+ Step-Thru as I am getting desperate to get the bike rolling. I am wondering how your experience has been.
Jay West
I haven't installed it yet but I have been exploring some avenues.  The 2 possibilities I have come up with are mounting it on the front of the seat post (interferes somewhat on the step thru, I have a step thru also) or mounting it on the side of the seat post.  The other possibility is move the rear fender rearward by using two 3/4" or 1 inch stand offs (spacers).  In doing this the controller would fit between the seat post and the fender. It is too wide to fit with out doing this alteration.
This would require new fender bolts perhaps 1 1/4" to 1/1/2" long and moving the small junction wiring box to the side of the seat post.  This perhaps would work if after doing this this it not interfere with the removal of the rear wheel.
Still pondering the best solution.
cssshb
Quote from: Jay West on June 16, 2023, 08:34:49 PM
Thanks for the information. I think when my controller arrives I'll put it on the front of the seat post. I just want to get the bike rolling and am okay with sacrificing the step-thru feature if it means I can actually just get the bike on the move.
Quote from: Altema on June 14, 2023, 03:44:14 PMLooks like the two most viable options are on the front of the seat tube (will interfere with the step through function a bit), or under the rear rack (will need cable extensions except for the taillight.
When I installed my 35A upgrade into my 2021 MiniST2, a couple of the cables were uncomfortably tight so I went in search of extensions.  I looked everywhere and asked everybody and NOBODY sold an extension for the 10-pin connector, shown below.  Amazon even had full kits, except for that one.
If this has changed, and 10-pin extenders are now available, please advise - I'd love to take some of the tension off the connectors.
