RadRunner+: Canada vs US Electronics and Motors
Started by Jay-Ryan, February 16, 2022, 12:15:48 PM
Jay-Ryan
So there seems to be a lot of chatter out there indicating the RadRunner Plus 750w US motor is, in actuality, a running at 500w/750w peak.  The Canadian RadRunner is advertized as 500w, no mention of peak...
Does anyone know...  Is it the same motor?  If I decided to trick out my (Canadian) bike, could I apply the exact same numbers, use the same parts as the much published 500w steady/750w peak motor?
Thanks for your thoughts and input.
Cheers!
Jay
I too have also heard that and I also heard that it's the same motor all the way around.
Something for you to try. Go to the display settings and change your wheel size from 22 to 20 and see if you can notice a difference. You do this by holding the plus minus buttons simultaneously. You can also change your cutoff speed from 20 mph and increase it.
Chris777
Controller locks you out at 500 watts. It's useless. The bigger motor is just excess weight.
SQFRad
You can thank regulations for the 500w limit on a motor that's almost definitely capable of peaking higher. Have you considered an aftermarket controller?
Jay-Ryan
Quote from: Jay-Ryan on February 16, 2022, 12:15:48 PM
So there seems to be a lot of chatter out there indicating the RadRunner Plus 750w US motor is, in actuality, a running at 500w/750w peak.  The Canadian RadRunner is advertised as 500w, no mention of peak...
Update: 30Kms put on the bike yesterday.  Although I still do not have a definitive answer as to the motor specs, there appears to be a limiter in place (Thinking the controller) which limits the motor to 500w...  Period.  steady 500w, peak, 500w.
Even though I programmed max speed up from 32kph (20mph) to 40 (25mph) with the goal of getting 24ishmph, bike still struggles to maintain 20mph.  I'm not a technical person, so I will wait to see results from more skilled people before wasting money trying to get optimal performance from it (And after warranty expires, of course).
Jay-Ryan
Quote from: SQFRad on March 19, 2022, 08:09:55 AM
As posted above...  Yes considered, but waiting for two things...  Someone more skilled than I to try it and report the findings...  Warranty to expire.
Cheers!
Jay
Chris777
Quote from: Chris777 on March 18, 2022, 07:18:28 AM
Past me you dum dum. Americans getting the Bolton upgraded controller have 750 WATT controllers and screens gather dust in their garage. Just get one to mail you the old one for a few bucks.
