chain guard RadWagon 4?
Started by Belgium83, January 21, 2022, 06:43:45 AM
Belgium83
Does anyone know where to find a chain guard for the RadWagon 4? Or how to make it?
Belgium83,
I can't give you a yes to either of your questions. However I also own a RadWagon4 and have noted the chain will sometimes come off of the front sprocket. It's only happened three times and only while I was pedalling lightly in seventh gear. If that's one of your issues, thus the questions you have, my fix is going to be to install a front derailleur somewhere along the top run of the chain in order to keep it lined up with the front sprocket.
Not sure if this helps you or not but I hope so.
Joel52334
Quote from: Belgium83 on January 21, 2022, 06:43:45 AM
3D print one, probably in a couple pieces.  Go to a local body shop, see what they might do.  I've had my RW4 for about 1 year.  Never seen a need.
Do make sure your chain goes THROUGH the kick stand.
