where'd you add your second battery?
Started by rabbid74, December 13, 2021, 08:19:11 PM
rabbid74
Hey Rad riders!  I'm planning to add a second battery with a datex2 and was wondering where folks have added a second battery on the Rad Runner?   Some options I'm toying with are under the passenger seat (ideal)  or on the front downtube, which would bum me out as I love the step-thru convenience of my RadRunner+.   Bonus points for pics of your second battery!
Thanks and stay Rad!
j.Au
I threw a hailong style 48v on the front tube and connected both with the Bolton battery parallel unit.  It has not effected my ability to step through the bike, but a bigger battery might.
Sirch
I've looked into mounting a second battery under the passenger seat myself but this limits the size/Ah of the new battery but the only other option is the front downtube or in my center console. Does anyone have pics of either of these areas having a battery mounted?
dan26ntn
Quote from: Sirch on December 23, 2021, 08:18:33 AM
I made a 14s5p battery out of NESE modules -  https://18650.lt/ - using Samsung 50E cells . They just barely fit under the seat in a battery bag ( https://www.ebay.com/itm/174530582367?hash=item28a2d5575f:g:qecAAOSwP-Jfm~G3     .
One note is , using this configuration, fitting a BMS module is very tough , as the battery is hard enough to wiggle under there as it is. I elected to go without a BMS and monitor it myself , so this route is not for everybody. I have 25ah of capacity and 58.4 volts fully charged .
Sirch
I ordered a larger hailong style battery that I'm going to try to fit in the default Rad battery spot and put the stock Rad battery under the rear rack. Let's see how that goes.
Joel52334
I got the 48v battery from "Big Game Bikes dot com" It mounted nicely on the bottom bottle nuts.  I just added a piece of closed foam on the top.  I haven't gotten the battery/balancer tool they offer yet.  I'm going to add a 3rd BGB battery, on the back of my large platform.  It should fit just right, across the bracket.
Joel52334
Quote from: rabbid74 on December 13, 2021, 08:19:11 PM
I got my 2nd 48v battery from Big Game Bikes, they also offer the datex2 or datex3 device.  for 2 or 3 batteries.  They have all the cables  you'll need.  Gareth is a very nice person to work with.
ElectricRides
https://www.youtube.com/watch?v=HrvXvJkpWBk&t=1s
Finished installing second battery to where the stock Rad battery is located and moved the Rad battery to under the rear rack. There have been a few minor tweeks since I uploaded this video (cable cleanup and moved the dual-battery adapter)
It can be a bit of a pain putting on and taking off the battery but it works great.
