Battery life
Started by Jjames, January 07, 2024, 04:22:04 PM
Jjames
Good day folks
Apparently, if one doesn't use the bike for an extended period, one should 'cycle' the battery every few months?
Does anyone know how (a plug in device/dummy load?)
How much (drain to 70%?
And how often?
Thanks
Cycling will help NiCd and NiMh, but I haven't heard of it with Lithium ion.
An ebike battery that sits for months will get out of balance as some cells have faster self-discharge than others. I just balanced one that had sat three months. Before letting it continue to sit, I should run it down to maybe 49 volts. Thanks for the reminder.
Quote from: Jjames on January 07, 2024, 04:22:04 PM
I imagine that leaving the headlight on would eventually run it down, and probably so slowly that you could check the battery voltage once a day. I have not been able to determine the wattage of the stock headlights and taillights, so I can't do the math.
mrgold35
I have 3 batteries from my two 2016 Radrovers (4000 miles on each rad) and one battery on my 2018 Radcity (1000 miles).  I've lost about +/- 20% range on these batteries.  I usually only charge to max levels before a ride.  I leave it a the whatever charge level in-between rides (30%-90% power range).  I can probably count on one hand when I needed to use 100% battery power on +8000 miles I put on the ebikes.  The range loss really isn't a factor for my riding habits.
