Throttle and PAS failure
Started by [email protected], September 16, 2023, 10:19:17 AM
[email protected]
We have a red city 5+ which we bought new in September 2022. The last half year, we have had a stubborn, intermittent problem where PAS and throttle suddenly fail while riding the bike. We have had two in warranty replacements of the wiring harness, which has failed to fix the problem when the PAS and throttle fail, there is still full power to the controller which remains on and the front and back lights which are illuminated. In spite of having full power the PAS and throttle are unresponsive and the bike is in effect a big, heavy, non-E bike, which we have to ride the rest of the way home ?the hard way?. Has anyone else had this problem and if so, how was it resolved? PS. There are no error codes to be seen.
Naranja_CT5+
Have you tried isolating the problem by either disconnecting the PAS or Throttle?
Do you have a multimeter to see if you have voltage to the motor? Could be loose or damaged connectors.
I have also read that the magnet/sensor of PAS get misaligned.
mrgold35
I purchased a Radcity 5+ for my wife in June of 2023.  We had the exact issue with zero PAS/Throttle power to the rear hub with 16 miles on the ebike.  Everything else worked like the lights, brake light, LCD, and no errors on LCD screen.  Rad sent a new controller after trouble-shooting and sending videos of the issue.  The replacement controller cables were longer than the original and that made it a little harder to install.  Everything is working for now; but, only put 70 miles on the Radcity since the fix.
