Throttle control RR6+.
Started by PVS, September 03, 2023, 01:33:59 PM
PVS
Hello,
I recently added the popular handle bar extension to my RR6+. I was very careful to not put any stress on the handlebar wires and cables. But shortly after the installation, my RR throttle is now acting like the wire(s) inside the throttle itself don't have secured connections.
Specifically, about 50% of the time, everything works fine. The other 50%-ish the throttle does not work. The big clue is that if I gently push the wire towards the rear of the bike (near where the wire enters the throttle), then the throttle kicks in and works fine.
Is it possible to dis-assemble tth throttle and inspect the wires and their connections? Or is it a one-piece unit?
Thank you for any advise or tips.
Paul
I don't know what it looks like inside the throttle but it is spring loaded.  Maybe you don't have enough of the cable to to fully give you the power.????
I had to adjust my throttle and brake levers to align them for my comfort.  BUT I have not added the riser.  Have you tried to reposition these 2?
Quote from: PVS on September 03, 2023, 01:33:59 PM
You could be shorting something. Have you tried cutting some of the zip ties to get more slack?
PVS
Hello Naranja,
Well I'm happy to report that your suggestion of removing my zip ties worked!
Not exactly sure why how a basic zip tie could short something, but since removing them, things are working as expected.
I'll either repositioning zip ties, secure with black electrical tape, or try velcro strips.
Thank you!
