Throttle
Started by Jackharrison, May 07, 2023, 12:08:41 PM
Jackharrison
The throttle isn?t working. Any suggestions?
santacruzpaul
Quote from: Jackharrison on May 07, 2023, 12:08:41 PM
Just the garden variety response here, Check ALL connections, Main wiring harness, controller,  ext.
Paul
Jackharrison
Appreciate the suggestion. I?ll go through it again.
Jackharrison
The throttle connections appear tight. I finally heard back from Rad via email. They are back online,but phones are still down.
I just want a throttle.
Jackharrison
Any suggestions on where to buy a replacement throttle for the Rad Rover6+?
I'm willing to buy one even though my bike is under warranty. There's no clue as to when the company will surface again.
Thanks in advance.
#5
Try Area 13.  They may have what you are looking for.  They are very helpful and respond quickly.
JimL
Just a note from some work I did on a 6+:  if the pedal rotation sensor wire is broken or disconnected, the throttle won't work.  I don't mean that the throttle won't work if you are not pedaling, the system just needs to see that "wiring" live in the harness.  I don't know why.  I made a "break out" harness that fit between the pedal sensor and the main harness, so that I could look at the pedal sensor with an oscilloscope (working on a different issue...without success).
I also took the right handgrip off and slid the throttle out on the handlebar to make sure there was not interference from the rear brake lever (it has a hall sensor, as does your throttle).  If in doubt, disconnect the brake lever switches and see if the throttle comes back.
RidenRad
When that happened to mine, the last thing I did and it worked was, at approximately the center of the handlebars there is a screw in connection on the throttle cable and I unscrewed it sprayed some CRC ELECTRONIC CLEANER screwed it back and viola it worked, Never had an issue since.
Try it, good luck.
Get something exciting between your legs, a Rad Rover!
Jackharrison
Thanks, everyone for your suggestions. I did find a disconnect. Once it was reconnected, the throttle worked fine.
I want to look for places along the visible wiring where I can put strain reliefs in place.
Jack
RidenRad
Glad I could help.
