Magura MT5e Brakes
Started by turbulent0flow, March 03, 2021, 02:51:33 PM
turbulent0flow
Hello!
Jumping in head first with my Rad Wagon 4 looking to upgrade the brakes.
I like the Magura mt5e Option, has anyone here used Magura on their Bike?
I need to know if I need the OPENER or CLOSER HIGO connector lever type, because its a German company the translation is a little off...
CLOSER = NORMALLY OPEN
OPENER = NORMALLY CLOSED
So does my RadWagon use "NORMALLY OPEN" or "NORMALLY CLOSED"?
Thank you
JTK77
Quote from: turbulent0flow on March 03, 2021, 02:51:33 PM
Hello!
Thank you
Hi
You need Normally open version.
I have installed MT5e's with Galfer rotors f223/r203.
George3
JTK77,
Am trying to identify the Galfer rotors that you used but I am not sure of the exact model. F223/R203 do not give me any results.  Could you please advise me? Also, did you purchase them direct from Galfer?
Thank you,
George
JTK77
#3
Quote from: George3 on March 06, 2021, 08:05:46 PM
JTK77,
Thank you,
George
Purchased mine locally.
Front is DB007W, adapter Galfer SB003
Rear is DB004W2, adapter Magura QM09
George3
Thanks very much. Off to the hunt I go.
the_natural
Quote from: JTK77 on March 04, 2021, 08:47:41 AM
Hi
To clarify, if the MT5e model says it's "Higo-Opener" then it's the wrong one? 'Cause that's what I bought and is finally about to arrive ... from Germany...
Thanks.
JTK77
#6
Quote from: the_natural on March 27, 2021, 06:58:54 PM
Hi
Thanks.
You need Higo closer, normally open.
Opener is the wrong one.
the_natural
Thanks. I realized I can switch the levers to Closer ones, but I may just send the whole system back. I'll have to do the math on what makes sense. Thanks again for your help.
[email protected]
JTK77,
I just purchased the higo Closer ones on Amazon, and I was wondering if they will work  straight away if I don't change the 180 rotors front and rear? Will I have to get an adaptor?
Thanks for the help.
Javier
George
JTK77
Quote from: [email protected] on November 12, 2021, 11:33:14 AM
JTK77,
Javier
George
You could use them straight but Maguras are designed to work optimally with 2.1mm thick rotors so Its would advice doing that.
