Rad Power Bikes Chat => Rad Modifications => Topic started by: bcf5016 on July 20, 2026, 08:43:41 PM
Title: Connecting into the accessory
Post by: bcf5016 on July 20, 2026, 08:43:41 PM
Hi! I am trying to figure out how to connect accessories (e.g. whip lights) into the accessory of my bike.
I actually was able to connect the whip light to the front light red julet connector (using a 48v to 12v inverter).
Then, I tried to wire the whip light into the 7-pin accessory connector under the seat, but it looks like whenever I try to connect the inverter to the red and black wires in the 7-pin accessory, the voltage drops down to 0.4v or something nominal (vs 12v expected coming out of the inverter).
I suspect that there is some sort of limiter to prevent a short on the draw from the accessory.
Does anyone have a diagram of the 7-pin julet connector that powers the accessory ports? I can't seem to find anything. Would prefer to tap into the accessory vs cutting into the system on the bike.
