Hi guys, I wish to put Ergon grips on my new RadMini 4 but I notice that the two original grips on my bike are different sizes. The right one is smaller because of the throttle. Most of the grips from Ergon come both the same size but there is one set that shows two different sizes. Have any of you replaced your old grips with Ergon grips and if so can you give me a link to the correct ones. Thanks so much.
Hi, did you get to change the grips to ergon grips? I changed my radwagon 4 grips to ergon GC1, the GC1 is developed specifically for upright and back-swept handlebars.Rohloff/Nexus version is the one you'll be after if you have kept the twist throttle.
ive been planning to swap my shifter to a grip shift so that this isn't an issue
Irish Rad,
Thanks for the info and photos of the Ergon grips and the info on what model to get for a Rad. Did you have any trouble removing the originals and then mounting these grips? What about the end caps? Thanks,
George
Hi George, I just ran a sharp scalpel down the length of the old grips to cut them off.... The ergon grips are lock on grips and come with end caps
