What is the safest way to store batteries in a house? Is there some kind of fireproof storage box suitable for this?
I am considering getting a RadMini Step-Thru 2 and would want to store the batteries indoors as I live near Detroit and it gets very cold in our garage where the bike would be kept.
I store both my batteries in my apartment on my bikes. I feel confident doing this unless the battery has been dropped or you've been in a crash .
I would then store my batteries outside for a couple of days and charge them outside and see how they do.
How cold is "very cold"? Better to store them cold than hot.
Quote from: DickB on January 05, 2022, 04:26:05 AM
Oh that is interesting. I wish I know about this before I topped off my Ryobi batteries for my mower.
Quote from: Enkidu on January 05, 2022, 06:25:45 AM
I would just run the mower for a while to get below 70% State Of Charge (SOC).
I have a 5-gallon metal bucket that used to hold paint when I painted my fence. I put the battery in the bucket and close it with a metal bucket cover. I figure even in a fire, the fire would be contained in the bucket and there would be limited oxygen. I keep the battery indoor and warm.
I'm not sure the metal buckets would contain a lithium fire. I've been told it burns over 1000f it doesn't need oxygen. But the same time it's better than nothing.
I store & more importantly charge my batteries in an old safe, I have put a chain as a handle on the safe if something were to happen , I can pick it up and put it outside. Also, have a smoke detector & powder filled fire extinguisher near to where you store or charge your battery. Mount your battery charger on an old metal rack/oven grill to let plenty of air circulated and keep the charger cool while charging.
safe
safe
safe
Curious - do you unplug your TVs and all other electrical appliances during a lightning storm? Because that is the safest.
Quote from: DickB on February 23, 2022, 12:26:46 PM
Hi DickB ,answering your question, I do unplug anything electronic like the TV in the house going to bed normally anyway, So I would do the same in a lighting storm. But we do not get too many lighting storms here in Ireland.A Lithium battery fire and a TV fire are a too different ball games .
I just understood a little more about lithium batteries and why it is so dangerous. The electrolyte in the lithium batteries is some sort of organic chemical - it is not some aqueous based solution.
To use an analogy - think of it like the insides are materials soaked with methanol/gasoline/acetone or something similar. I am using an analogy and this is not correct of course. It just helps you to think of it. With a short causing a spark, and with access to oxygen if the battery cracked open, the battery will burn even if your battery is safely discharged to absolutely zero charge. It is not just the stored charge that is dangerous. The material itself is very burn-able (flammable in vernacular).
This is in addition to any danger posed by the stored charge/chemical energy that can be released without additional oxygen.
Lithium is pretty terrifying when it goes sideways. Its like a caged lion.
Quote from: Radio Runner on May 25, 2022, 11:32:05 PM
Vapers have had fires because some of the devices come with unsafe 18650 cells.
https://www.dnkpower.com/why-18650-battery-explode/
These experts say the modern 18650 battery is quite safe if it's a good brand. They're made not to short internally. They have valves to prevent explosion. They have internal circuitry to prevent dangerous current in or out.
They recommend charging at 20 to 26 C. Too cool isn't harmful, buy you may not get a full charge. I've sometimes charged in the garage, but I guess it's not a good idea.
They say not to use these batteries in humid conditions. How would you avoid that on an ebike? They don't say why or how humid.
Quote from: Enkidu on January 04, 2022, 08:40:33 PM
... I am considering getting a RadMini Step-Thru 2 ...
QuoteI wish I know about this before I topped off my Ryobi batteries for my mower.
Well, that's a double coincidence. I recently bought both a RadMini ST2
and a Ryobi cordless electric mower.
Quote from: John Rose on November 26, 2023, 02:39:22 PM
Well, that's a double coincidence. I recently bought both a RadMini ST2 and a Ryobi cordless electric mower.
That reminded me to check the lithium battery of the hedge trimmer I bought in 2022.
The nicad battery on my B & D hedge trimmer lasted many years. When it deteriorated, I bought a B & D nimh battery, which was supposed to be a replacement. I soon had trouble, so I bought a brand that was supposed to be better. Same thing. I thought it must be the charger. New charger, same thing.
It turns out, the B & D charger, which was supposed to be good for both types, would drain a battery at a few milliamps. When the battery came down to a certain point, the charger would come on and top it off. That seems to be the best way to maintain a nicad and why the original battery lasted so many years. With nimh, there's a drain current but the charger never comes on to top it back up. It's best not to leave the battery on the charger. B & D never explained that. They surely made a lot of money manipulating consumers into replacing batteries and chargers.
Several times a year I needed to cut back an enormous hedge with hand tools because the electric trimmer wasn't aggressive enough. When I saw a more aggressive one marked down, I bought it even thought it was B & D. It's lithium. B & D said to recharge it after each use. I wasn't inclined to believe their battery advice. I'd charge it only when it began to slow down.
Your mention of a Ryobi mower made me think. I read 16.6 volts on the 20 volt battery. I don't know what kind of cells the B & D has, but suppose it's 5 in series, which could be 20 volts fully charged and 18.5 nominal. I put it on the charger for an hour or so, measured 18 volts, and it was still 18 when I checked after it had sat an hour.
If they published state of charge vs voltage charts for particular batteries, I could see if a battery was suitably charged for storage.
