Rad Power Bikes Chat => Rad Modifications => Topic started by: Altema on August 01, 2022, 04:36:25 PM
Title: Bafang got cheaper...
Post by: Altema on August 01, 2022, 04:36:25 PM
I mentioned in another thread that I did a motor swap in Delaware. This was due to a hall sensor failure, but as things turned out, I'd ordered a replacement motor that was supposed to arrive after my trip, but it arrived the day before the trip, so I took it with me! The new motor worked fine, but after a high speed ride alongside gas bikes, I noticed an odd noise that sounded like gears slipping. I pulled the motor apart and found the nylon gears were fine, so I switched the clutch out, and still had the noise.
The ring gear tested fine as well, then I saw it: The replacement motor was missing the internal lacing! That's the string-like cord used to secure the coils and other bits. Without it, the wires are subject to vibration and movement, and this leads to metal fatigue and failure. This is common is cheap throwaway motors, but motors built to last usually have the internal lacing, I was surprised Bafang went in this direction. The only reason to do so is because it's cheaper and saves time and materials. The motor itself works fine, and although the motor on the right is better made, it's out of commission due to the sensor failure. So I went to the hardware store, got some appropriate string, laced up the critical spots, glued the knots, and tested it. The noise is gone and I can use full power again, so we shall see how it holds up!
Title: Re: Bafang got cheaper...
Post by: JTK77 on August 02, 2022, 12:43:13 PM
Quote from: Altema on August 01, 2022, 04:36:25 PM
Not sure If its intentional or lack of QC.
What I recently noticed that the gluing of motor magnets was not accetable and failed. Now after fixing this issue together with other mods the motor is way better than new 😄
Post by: JedidiahStolzfus on August 02, 2022, 01:58:34 PM
Do you see that black part with the 3 legs on the left side of each motor?  That's the hall effect component.  I'd bet it's a fairly common device that could be easily replaced if you just have a soldering iron and some solder wick to remove the old solder.
Post by: Altema on August 04, 2022, 01:58:13 AM
Quote from: JedidiahStolzfus on August 02, 2022, 01:58:34 PM
Yes, I just need a source for the sensors. I wonder if the sensors from the Bolton motors would fit, since I have three of those failed motors on my workbench right now.
Post by: Altema on August 04, 2022, 01:59:33 AM
Quote from: JTK77 on August 02, 2022, 12:43:13 PM
What glue did you use? I used CA on mine, but that glue has failed on other motors.
Post by: JTK77 on August 04, 2022, 09:47:48 AM
Quote from: Altema on August 04, 2022, 01:59:33 AM
Permabond ET5441 heat cured after 24h  in 85?C 30min.
Post by: Omidia Ramin on August 04, 2022, 01:22:38 PM
I hate to hijack a thread, and I?m not sure if this counts, but I think you?se have the answer (those on this thread:-) )
I have a motor (the one out of the mini 4) with a broken axle. It?s been replaced, but I?ve kept the motor, if for nothing else wall was art.
How feasible/possible is it to replace an axle on these things?
Would be nice to have a spare and send like a shame since the rest works.  Should I perish the thought or what??
Anyways, thanks for any thoughts!!
Post by: JedidiahStolzfus on August 04, 2022, 01:52:13 PM
Quote from: Altema on August 04, 2022, 01:58:13 AM
If the head of it lifts off the board, then look at the number, chances are Mouser has it.  I might even have some in my parts.
Post by: Altema on August 05, 2022, 06:36:03 AM
Quote from: JTK77 on August 04, 2022, 09:47:48 AM
Thanks! I've got 4 motors I needs to do... any tips on cleaning the old glue off?
Post by: Altema on August 05, 2022, 06:44:29 AM
Quote from: JedidiahStolzfus on August 04, 2022, 01:52:13 PM
I found the sensors and ordered them off eBay last night. Also ordered a DC motor tester that can tell which of the three sensors is bad.
It's funny that I saw a motor advertised which had dual hall sensors for backups, and I thought "who would need that?". Now I know... 😂
Also realized I could have just configured my Phaserunner to run the motor sensorless on the trip.
Post by: Altema on August 05, 2022, 07:19:11 AM
Quote from: Omidia Ramin on August 04, 2022, 01:22:38 PM
I loaned my original RadMini motor out so can't check, but on my other Bafang motors, it looks like you can remove the axle. It will be complicated though because you'll have to remove the wiring that goes through the axle, feed it back through, and resolder it. Might not be worth all the work.
Post by: Altema on August 06, 2022, 01:20:32 PM
Quote from: Altema on August 05, 2022, 07:19:11 AM
Hey, I just found a video on replacing the axle! Here's a link if you want to see what's involved in this job...
https://www.youtube.com/watch?v=Tb3mXqU1CJs
Post by: JTK77 on August 06, 2022, 02:14:46 PM
Quote from: Altema on August 05, 2022, 06:36:03 AM
Cleaned first with acetone and scraper tool. Then prepared surfaces with 400 grid and removed dust.
Just before applying the epoxy cleaned the surfaces with acetone again.
Post by: JTK77 on August 06, 2022, 02:20:34 PM
Quote from: Altema on August 06, 2022, 01:20:32 PM
The most hardest part is to source new axle (with decent price).
