hello, Rad friends: Is it possible to raise handle bars on rad rover 6? in any possible way? thanks
I used a Delta Stem Riser on my Rad Rover ST, the taller one 4.6. Bought it on Amazon (https://amzn.to/3PYJPjV), nice riser don't need all the spacers and is easy to adjust.
Hey! that's cool, thanks for the idea, I purchased the same delta stem riser you used, the 4.6. I have the Rad Rover 6 ST like you, did you have any trouble with cable lengths extending 3" - 4" higher? Appreciate the help, this will go a long way to alleviating back/neck pain, bless you.
On my 2021 Rad Rover ST, I raised the bars as high as I could on the 4.6 riser and the cables were just long enough to steer fully in both directions. No problems so far. Sure is a lot more comfortable sitting straight up. Good luck!
