42mph Rhino
Started by JTK77, June 07, 2021, 02:54:10 AM
JTK77
This "slightly" modified beast does 42 mph on level ground. Speed is plentiful so PAS 3 is often the most used assist level at speeds of 30-35 mph. Torque is enough (for accidental wheelies  ;D).
Tony
nate427
Is that with the stock motor? What exactly did you do to modify it?
JTK77
Quote from: nate427 on June 10, 2021, 08:02:16 AM
2017 Rad Rhino (/Rover).
60v 24Ah 120A BMS (continous) lockable downtube custom battery.
45A sine save controller.
Vented G062.1000.DC motor.
100mm Air fork.
Magura MT5e f223/r203 (Galfer) brakes.
52t chainring 8 speed trigger shifter 11-42t cassette.
780mm Rad Devil Riser handlebar with full grips, thump throttle, fork remote lockout.
Custom Kydex "carbon" skid Plate.
+ Other mods & parts.
42mph ~3 kW.
jbfoster
Wow that's a bit fast for me on a bike.
Jim
netjamer
I want one like that.. the wheelie thing got me!
natchezz
THAT is a great looking, might I say "bad a$$", bike!  8)
Nice! I use the same motor, but the smaller wheel son the RadMini means a lower top speed. It still gets me an honest 30 - 32mph, but I've done 35mph in the tuck position to reduce wind resistance.
JTK77
Quote from: Altema on October 09, 2021, 10:22:45 PM
The motor is quite awesome for its size 🙂. I did add some vents on both side cover to further improve cooling (+generous greasing with SHC100).
Runs nicely and not too hot with 60v 48A (~3100w Max).
Quote from: JTK77 on October 11, 2021, 11:39:30 PM
Wow, 3100 watts? I know Bafang builds some overhead in, but that's a lot!
I have mine limited to 2000w until I get comfortable. I was going to take the peak up to 2400 soon, but am considering using Statoraid for cooling instead of vents since I sometimes ride in the rain. It currently peaks at 2045w with 52 volts, but I get a solid 32mph with 30amps of field weakening. Did you add a thermistor to the motor?
JTK77
#10
Quote from: Altema on October 12, 2021, 08:50:27 PM
I know adding holes in geared hubs is not "widely recommended" but with generous greasing and yearly maintenance I decided go for it. Little waters isnt that bad but sand and dust can be. Added benefit to this approach is I can do IR temp measurement straight from the windings. I did concider adding thermistor later but haven't done that yet.
The reason why I didn't took the statorade route is because geared hubs have Air Gap between motor and casing that prevents heat from dissipating out.
Quote from: JTK77 on October 13, 2021, 02:05:04 PM
Thanks for mentioning that, I completely forgot about the second air gap on geared motors. Makes ferrofluid kinda useless, lol.
It rains a lot where I live, then when I go to Delaware for group rides, we often go in deep loose sand. It has enough power with just the 2000 watts I'm using now, so I think 2400 watts on occasion with no vents should be ok. Either that, or I can make the holes a specific size, and plug them with caps when needed. The Phaserunner can modulate maximum power based on temperature, so I might just install a sensor and use that option.
JTK77
Quote from: Altema on October 13, 2021, 03:58:41 PM
Yes that power level will be ok. I did ran this motor without vents with 60v 35A for ~1000 miles without any heat problems. I know few other have done similar power levels without problem.
Quote from: JTK77 on October 13, 2021, 09:11:59 PM
Thanks for the info. I'll probably only turn it up past 2000w for special occasions where I'm running dual batteries. Most of my batteries have a 40A BMS, so with a single 52V battery, it limits me a bit  ;)
Well I turned it up, and what a blast. With the smaller wheels on the RadMini, the torque is hilarious, and I'm getting 34mph with a modest amount of field weakening.
I had a question though: how many amps is the BMS on your battery, and do you run with a single battery or duals?
