Author Topic: New RR+ brake adjustment/coasting resistance  (Read 387 times)
XplsvAmnesia
« on: September 28, 2021, 10:05:26 AM »
Just got my RR+ yesterday, built it myself. I rode into work today and even on a downhill with pedaling I couldnt break 25mph. This is my first E-bike I wasn't sure if the motor creates drag, or my other thought being that maybe the brakes are maintaining light contact with the rotors. Thoughts?
Sirch
Re: New RR+ brake adjustment/coasting resistance
« Reply #1 on: October 14, 2021, 08:14:05 AM »
I can't find it now but I was reading a thread the other day (either here or on reddit) that was talking about the motor drag while going downhill to prevent the bike from going too fast. Sorry, can't find it but it sounds like what you are experiencing.
Edit: Found the reddit post - https://www.reddit.com/r/RadPowerBikes/comments/q6bc4v/radrunner_drag_on_downhills/
« Last Edit: October 14, 2021, 08:56:00 AM by Sirch »
XplsvAmnesia
« Reply #2 on: October 14, 2021, 02:04:40 PM »
Thanks, comically that reddit post is from me haha. The consensus does seem like the motor is causing drag at around 25mph
Sirch
« Reply #3 on: October 14, 2021, 03:27:35 PM »
Hah, /facepalm!
Seems kind of silly for the motor to actively prevent a rider from going "too fast".
RadFunner
« Reply #4 on: October 18, 2021, 03:38:28 PM »
I'm here to tell you I've had my RR+ up to 31 MPH going downhill, pedaling my legs off. I doubt if I could get it to go any faster without adding another gear or to. And NO, I have not changed the settings on my display. just sayin it is possible.
RadRunner Plus
Ray.Marx.67@gmail.com
« Reply #5 on: December 26, 2021, 07:04:54 PM »
On flat land without any mods, I have only been able to get to 23 but, going downhill, I have been up to 38mph while coasting, no braking, depends on the hill and grade. And I haven't checked yet to see what, if any, discrepancies the controller shows, with the speedo. That's using both the pedals and the throttle until it goes faster than I can pedal or throttle works. This is with default setup and changing to 40km/h in settings, only.  There's a lot of long 6-10% grades around here.
Radding Along
  • Jr. Member
« Reply #6 on: January 13, 2022, 08:07:28 PM »
Itís a class two bike. That means itís governed to 20mph by the Federal Government. When your bike reaches 21 or 22mph, pedal assist and throttle are abruptly cut off. So you can continue to pedal hard to achieve 30mph, but you wonít get any assistance from the motor.
And to answer your question about drag on the motor after reaching 20mph, that is not the case. What you are feeling is a 60 or 70lb bike losing itís helper motor.
Sounds like your bike is operating properly according to the governentís eyes.
