If anyone has installed the Electro Bike World 35 Amp controller on a Rad City 5 Plus I would like to know where you placed the controller unit on your bike. Thanks in advance.
Hi there! Apologies in advance for not answering your question, as I am wondering the same thing. Have you tried installing the upgrade kit yet or are you doing research still at this point?
I am also working on installing on a 5+ (step thru) and I am noticing that a lot of the connectors are not compatible with the bike's stock connectors.
I haven't tried or installed the 35 amp controller yet and therefore I have not checked all of the connectors yet but the two I have checked seem to be OK. My Rad City 5 + is also a step thru. I did purchase an extension for one of the cables from electro bike world as they said I needed it, but this is as far as I went on the installation.
The problem I see with the install is the controller will not fit on the back of the seat tube without some modification as it is too thick to mount there. I could mount it on the front of the seat tube but being a 87 year old man I wanted to keep the area in front of the tube open for the ease of mounting the bike. I just thought someone might have a better idea on mounting the controller. I believe the cables are OK but I may be wrong.
Thanks for the reply.
