Does anyone have experience of 250W EU Rad with EggRider V2? Is it worth buying?
I am a happy owner of new RadMini 4 (250W) for a couple of days and I would be super happy with some extra power. But not trying to build a rocket.
Hi, were you able to find out if it works? Just ordered a Radmini 4 EU myself
I don't know about the Eggrider but I did find the 250 EU Mini lacking in power when going up a steep hill with my grandson on the back and extra shopping loaded. So I fitted the upgrade 35 amp controller from Big Game Bikes , problem solved .
Quote from: Blasterqueen on June 12, 2021, 03:04:05 PM
No, not yet. But I ordered one (from Big Game Bikes) and I hope it arrives soon.
I'll report here when I have some experience from it.
Eggrider V2 works great with EU RR(+) ( And I don't foresee anything different for the radmini )!
I've logged about 1090W peak power output on some steep hills and hit ~41km/h ( in a controlled environment )
PAS difference will need time to get used to, but I'm fairly happy and have logged 830km with it already :)
Quote from: anotherviktor on July 01, 2021, 09:30:09 AM
Good to hear that!
I got mine today. First ride whit it tomorrow.
Quote from: Kari on July 01, 2021, 01:17:11 PM
Good to hear that!
Hope it's a blast!
I'd recommend printing a sun hood for it: https://www.thingiverse.com/thing:4583482 ( You can also find a bottom bracket print for eggrider in thingiverse since they can break easily if you go too right )
Wow, impressive! Is that with only the EggRider, or were other changes made?
What is the PAS difference?
(I tried searching but no luck)
Quote from: Altema on July 01, 2021, 04:03:09 PM
Only the Eggrider with the offroad mode Amperage setting set to 19A :)
Edit: Now that I'm re-reading my comment, my top speed record wasn't on a hill, just flat road with ~850-900W output
Quote from: garth@garthy.com on July 02, 2021, 09:15:26 AM
Eggrider will not offer you the smooth PAS that native Rad controller has. It's a bit jerky and not so "gracefully" smooth. They have been releasing updates that improve things on that end. I usually either ride on PAS 2 or 3 and high gears for a workout, or PAS 5 for fun/when time is an issue.
Quote from: anotherviktor on July 01, 2021, 03:55:43 PM
Good to hear that!
Hope it's a blast!
3d printed sun hood came with it.
More power (a lot of more), but less smoothness.
Now 47 km testing behind and end of the day I'm gonna change back to original screen.
I'll give it another change when there is new update available or I get more info to adjust it for my needs.
Hi from Austria, at my Radrunner the Eggrider works without problems over 2000KM. Maximum Power is over 500W and in sport mode full throttle functionally. One important thing: at the controller label is the maximium Ampere written, in case of the lishui controller in the Radrunner 10.5A. This value must be written in the app under the controller settings. And further, with the newest update there is a setting ,,radpower mode" for more smoothness. In the next hours i will become the radwagon4, this bike will become the eggrider too, i will report ;-)
Hi All!
I have a eggrider v2 on a EU Radwagon 4 and it works perfectly.
I had one of the EU Rad Rhino 750w and the radwagon 4 with the eggrider gives you a similar feel in terms of power and speed.
Could you guys share your eggrider settings? Mine seems to never show 100% battery charge and I think than I could tweak the settings to get better range...
I just read about the Rad Power settings in the new firmware. How you set it up?
Thanks!
Quote from: picacoco on July 13, 2021, 06:39:10 AM
Hi All!
Thanks!
The settings differ from model to model - I got mine from the Eggrider FB group!
What are the battery settings you have set?
I have mine @ 39V for 0%, 54.2V for 100% and 14Ah capacity
Could it be that your battery no longer reaches the voltage you have set?
Hello from Austria, here are the settings of EggriderV2 with my 2020 RadRunner
And the settings Eggrider V2 with our new RadWagon4.
Quote from: anotherviktor on July 15, 2021, 09:03:15 AM
Hi All!
Thanks!
I went back to it and now with your settings I get the 100%!
Thank you Mostviertel50 for sharing yours, I'll check them as well!
Hi
Can someone also post the settings for power levels and if any updated lishui once for a EU radwagon 4
Thx
Quote from: Mostviertel50 on July 19, 2021, 02:30:38 AM
One question, why did you set up wheel size in lishui settings to just 20" .. The Radwagon 4 has 22"
