Has anyone found a good way (product) to mount and Air Tag on a RadRover 6+?
Duct tape it inside of a fender.
One could check out the Tagbox from Pinhead. I haven't ordered one but eventually I might.
i ordered this: https://www.etsy.com/listing/1053341016/galaxy-smarttag-bike-reflector-stealth
i believe he's got them for airtags too.
i put it on my seat tube.
Tree, that airtag holder looks good. Small, simple and not obvious. Nice.
It would be great if it was mounted more permanent but overall a good idea.
Quote from: Ddaybc on November 26, 2022, 08:45:02 AM
make sure you get the one that matches your device. i just use a zip tie and put it on my seat post. i'm sure there are better places for it. but if someone is stealing my bike to use it, they're likely not removing the seat.
If a thief has an iPhone, they will be notified in 3 hours that they are being followed by an Airtag and can activate the buzzer to help them locate it. Here is a solution that might help keep it hidden longer if you are confident enough to dismantle and reassemble your Airtag. https://www.youtube.com/watch?v=gSRc1DScOY8&list=WL&index=13
as previously posted if you can, remove the speaker from the air tag before hiding it. My self I found on the Rover 6+, that the empty space above the battery and behind the lock core is a great location. there is no access to this spot without removing the battery and a number of screws. the range is decreased by being in the down tube, but it does still work.
I tucked my "TILE - Button" under my controller. It's just a "black bump" way under there... I may add another to a fender; that's a good idea too.
I use a bike Bell that hides an airtag. Found it on Amazon and it?s a better bell than the original.
Upcoming iPhone IOS 17 will allow more than one iPhone to track an air tag.
Covered up with tape under my Seat...
