Rad Power Bikes Chat => Rad Modifications => Topic started by: wapple on July 21, 2021, 01:02:51 PM
Title: Remove Radrunner Max Speed Limiter
Post by: wapple on July 21, 2021, 01:02:51 PM
Anyone tried blocking the radrunner's speed limiter lately?
Saw this video from last year around placing a piece of tape over the connection that regulates speed. Anyone done this? Would it work on radrunners made this year? There was a similar thread from last year about just cutting this wire too.
Would love to hear from you!
https://www.youtube.com/watch?v=1BDSllZzRYA
Title: Re: Remove Radrunner Max Speed Limiter
Post by: SDrider on July 22, 2021, 09:28:15 PM
If you have the Plus with the upgraded controller, you can easily upgrade the top speed to 25mph by pressing a few buttons. Not sure about the stock Runner though, the electric tape could be the only solution.
Post by: MurderNote on July 23, 2021, 01:08:54 AM
I just got my RR a few weeks ago. (Not the +) and did the tape trick. It worked. I also just ordered the Eggrider V2 from Luna Cycles. I haven't gotten it yet so I can't speak on it. But it's supposed to be plug and play. I can't wait to try it out.
I guess in the past there was an issue that caused some jerkiness when accelerating but it was apparently addressed in the latest firmware update. Also, the Eggrider is used to more improve torque rather than speed. Especially in steep hill situations. There's some videos on YouTube if you want to check it out.
Post by: Jgonzo on July 25, 2021, 04:47:31 AM
It worked on my Radmission, however the odometer and speed stopped reading. The accelerator did not go faster than approximately 25mph, as far as I could tell but I could pedal much faster with continued power assist.  I changed it back and simply reprogrammed the bike to 25mph which is plenty fast for where I ride.
Post by: Altema on August 02, 2021, 10:01:38 AM
I tried the tape trick on my RadMini. The speedometer stopped working but the bike did not get faster, so I guess it depends on the model.
Post by: wapple on August 06, 2021, 08:13:27 AM
Quote from: MurderNote on July 23, 2021, 01:08:54 AM
let me know how you liked the eggrider. also would you keep the tape trick after installing or remove the tape?
Post by: Mooree on July 11, 2022, 07:10:41 PM
The speed limiter can be part of an electric bike's safety features, but for adrenaline junkies who ride at top speed like me, it can be too restricting. Removing speed limiter (https://biketoworkday.us/remove-speed-limiter-on-electric-bike/) on an electric bike can be easy by removing the bicycle limiting wire. It is usually found at the controller and normally comes as a single wire.
Post by: lucmorneau on July 28, 2022, 04:33:43 PM
Quote from: SDrider on July 22, 2021, 09:28:15 PM
Can you be specific about wich buttons ?  The electric tape not working with the 2022 model.
Post by: HeyRyGuy on August 05, 2022, 11:18:27 AM
What is this button sequence?
Post by: JedidiahStolzfus on August 05, 2022, 11:20:56 AM
Quote from: HeyRyGuy on August 05, 2022, 11:18:27 AM
Power on the bike, press the UP and DOWN buttons at the same time.  That takes you into the programming mode.  Using the Mode button scrolls through the options.  Use the arrow buttons to change the values.  Up the speed to 40KPH.
Post by: Hugh on August 25, 2022, 09:19:23 PM
I just installed a Bafang 1000W rear hub.  What a difference.  There are photos of the stock RAD motor armature next to a Bafang 750W armature that shows how much smaller the RAD armature is compared to a Bafang 750W armature.
Post by: JimInPT on August 26, 2022, 07:29:36 AM
Quote from: Hugh on August 25, 2022, 09:19:23 PM
There are also photos showing that a lot of that "bigger" motor space is empty.  DickB and Altema here on the forum are experts in this area.  If you experience a performance improvement, it may be due to the lack of speed-limiting circuits built into the Rad motor, if I remember correctly.
Post by: JTK77 on August 30, 2022, 09:04:56 AM
Quote from: JimInPT on August 26, 2022, 07:29:36 AM
No speed limiting circuit in Rad (Bafang) motors!
More copper (strands in multistrand winding) in 750w motor. Little more torque and efficiency as result.
Post by: Rover on August 30, 2022, 07:05:38 PM
There are Youtube videos also that show how to up the speed capacity on RR 6 Plus and City 5 Plus. The videos walk you step by step of the instructions posted above by Jedi...
Post by: Altema on August 31, 2022, 09:18:00 AM
Surprise! Yeah, the Bolton motor is "bigger", but what you're looking at is a fat magnet structure that covers up empty space. You can't measure electrical specifications with your eyes. What makes a 750 watt motor a 750 watt motor, is it's ability to operate at 750 watts and stay within it's temperature parameters indefinitely, meaning it will never overheat at that power level. This is the nominal rating. Both the Rad and Bolton motors handle 1600 watts peak, though the only motor I've had overheat is a Bolton, not a Rad.
Below is one of Bolton's Bafang G060 motors on the left, and a Bafang G062 motor on the right. The smaller motor handles far more power.
Post by: JimInPT on August 31, 2022, 11:24:25 AM
Am I misremembering about a speed-limiting circuit in the Rad-spec motor?  I seem to recall discussion about how even a higher-voltage battery won't make them spin faster, like the Bafang-branded motors do.  I'm happy with 25mph on my MiniST, so have never pursued this aspect very far.
Post by: JTK77 on August 31, 2022, 09:21:29 PM
Quote from: JimInPT on August 31, 2022, 11:24:25 AM
I have some experience with these motors. There is no speed limiting circuit but loaded speed (aka real topspeed on road) is combination of motor phase input voltage, motor KV and motor phase input current.
Increased voltage alone does not nesessarily increase topspeed alot of current is limiting.
Motor no load speed increased very close to linear with increasing voltage.
There is reason why topspeed and no load speed varies with individual "Rad motors". Rad has used motors with some different KVs. This is indicated by motor turn count number. As a result using controller and display without speed limit hard code max (40km/h) no load speed can be seen to vary.
Post by: K2WW on September 14, 2022, 04:06:11 AM
JTK77-What's this KV you speak of?
Post by: JTK77 on September 14, 2022, 07:34:52 AM
Quote from: K2WW on September 14, 2022, 04:06:11 AM
Motor parameter. Simplified explanation is how many revolutions per volt the motor is turning at certain input voltage when not loaded.
Example 48 volt battery will turn 10rpm/V (KV) motor ~480rpm (per min).
Post by: Jsoares88 on September 22, 2022, 09:51:53 AM
Meanwhile, while i was reading this topic searching for a solution for the EU 25KM/H speed limit, i just found it very very simply on my Radrunner Plus 2022.
If someone still needing help just let me know 😊
