Rad Power Bikes Chat => Service & Repair => Topic started by: nuthatch on May 15, 2020, 07:18:43 PM
Title: Radmini creates drag while coasting
Post by: nuthatch on May 15, 2020, 07:18:43 PM
Hi - A friend bought a Radmini this spring and has a problem with it slowing down going down hill - The brakes are not dragging - It will not coast above 25 mph no matter what he does - He called Radpower bikes and got very little help - He was told to take a video of it happening - They suggested to him the possibility that the bearings in the motor may need to loosen up - Has anyone else experienced this or does anyone have any ideas on what could be causing this? - Thanks in advance
Title: Re: Radmini creates drag while coasting
Post by: Fisher65 on February 13, 2021, 01:55:34 PM
Just posted on exactly this topic.
https://www.radowners.com/index.php?topic=790.msg3919#msg3919
I think it´s normal. My 2018 Radwagon has done this since new and I think it´s the way the controller is programmed. Just what it´s doing I´m not sure as when you get this drag going downhill it does not seem to be regenerating energy into the battery.
Post by: Veggyhed on February 17, 2021, 10:11:56 PM
I have a mini 4 2020 and there is only one long hill that I come down and I normally hit 27 mph coasting. I don't remember feeling drag but also I never try to get it above 27 mph. I would say I'd go try it right now but we have ice and snow on the ground.
I would imagine they would have to be some drag from the back wheel. If you have it up on a workstand or upside down and you spend that wheel there is some drag.
Post by: steevwatson on February 20, 2021, 03:17:32 AM
I have a Mini 4 and I have one big hill that I commute down daily.  I need to be careful I don't exceed the the 30mph speed limit when coasting so it definitely sounds like something is up.
Sent from my Pixel 5 using Tapatalk
