Recently someone asked about the pros and cons of each model offered by Rad Power Bikes. For those completely new to electric bikes or maybe bikes generally it would be helpful to have some sense of the key benefits of each before they decide which model to buy. This is going to be the topic of my latest video but I wanted to see if others had any thoughts in addition to the ones I have below. I am trying to keep it objective and simple, avoiding things that might be pros for some types of riders and cons for others (i.e. the RadRunner is a smaller bike and is great for perhaps people who are shorter, but might not be suitable for someone very tall). Note that none of the cons should be seen as deal breakers, I think there is a use case for every model. I did endless research before I decided to buy our RadWagon. Appreciate any additional thoughts!
RadRunner (65 lbs)
Pros:
Cheaper price point
Built in rack (passenger and cargo)
Higher torque
Cons:
No LCD (Upgrade available)
No front suspension
Single speed
Not as common tire size
Fenders cost extra
RadWagon (73 lbs)
Pros:
Lower step but not step-thru
Regenerative braking
Cons:
Long
Lower torque than all other models (same as RadCity)
No front suspension
RadRover (Step-thru 71 lbs, Standard 69 lbs)
Pros:
Step-thru option
Best for off-road
Best in snow
Stability of fat tires
Front suspension
Cons:
Rack adds additional cost
More rolling resistance with fat tires
RadMini (Step-thru 69 lbs, Standard 67 lbs)
Pros:
Step-Thru option
Foldable
Stable with fat tires/ability to go off road
Cons:
RadCity (Step-thru 65 lbs, Standard 64 lbs)
Pros:
Step-thru option
Integrated rack for cargo or child passenger only with Thule Yepp Maxi
Most approachable if already used to a standard bike
Front suspension
Cons:
Lower torque than all other models (same as RadWagon)
Hi all, here is my video going through the pros and cons of each Rad Power Bikes model. I linked the video to this post so if you have any additional thoughts for prospective buyers share them here.
https://youtu.be/_26SXoECwnM
