I bought a 2017 Rad Mini, I need a new battery. Wondering if there is a better option then buying a $400 battery direct from Rad.
Thanks, Dale
I would buy a good aftermarket battery from Amazon or somewhere else. It will likely come with a new mounting plate/wiring. Those are generally an XT60 connector. The website below sells dual battery kits, but they also sell adapter cables for Rad so you don't have to cut/splice any wires. You can get an XT60 to Rad adapter cable for like $20 that you can use with the aftermarket battery.
https://electricallwheel.com/store/ (https://electricallwheel.com/store/)
