Almost ready with my custom 60v 24Ah lockable downtube battery. Fitted with 120A/400A Daly BMS. Made of Samsung 40T 21700 cells.
That interesting. Sounds powerfull.
you are saying rad bikes can support 60 volts with stock display, controller and motor?
Quote from: JTK77 on May 19, 2021, 12:11:25 PM
is this something you're developing to sell...or personal mission?
Quote from: ejonesss on May 26, 2021, 11:26:18 AM
Stock motor can handle 60v no problem. The problem with stock motor and wiring is they do not support that much amps. You can concider 25A as "safe" limit. Above risks for failure becomes more evident.
Stock controller and display support max 52v battery.
I have replaced every electrical component on my bike.
Quote from: wkindred on May 26, 2021, 11:38:23 AM
This is something that I wanted to take as personal challenge/project. Not planning to build more as I`m not expert in batteries + lot of work to accomplish.
If the Rad controller does not raise its 750W limit with a higher-voltage battery, there would be no increase in amperage to the motor.
Quote from: DickB on May 27, 2021, 05:17:15 AM
Rad controller limits only amps.
Quote from: JTK77 on May 26, 2021, 11:10:44 PM
And to add to that, the Bolton controller also tops out at 52 volts. It may be able to handle more voltage, but settings for the low battery cutoff point won't support it.
