Hi folks,
I have a question about a replacement motor cable for my 2019 RadWagon:
My motor cable (the electrical wire between the black box in the middle of the frame and the rear wheel) is broke. The 2 connectors were pulled apart while riding and the cord connected to the rear wheel motor wrapped around the wheel and when I removed it, the male connector (with the 3 prongs sticking out) got mangled. Long story short, the connector needs to be replaced. everything else on the bike seems to be fine, i just need a new male connector.
See the enclosed photos but does anyone have an idea on where I can get a replacement connector to splice in? When I contacted Rad Bikes, they recommended replacing the whole motor which would cost $350, but it is only the connector.
Thanks for the help!!
Best, Jeremy
jeremyogusky@gmail.com
I believe this is the cable you can splice in.
https://m.aliexpress.com/item/3256803434878398.html?spm=a2g0n.detail.1000014.11.1dddov0sov0sNX&gps-id=platformRecommendH5&scm=1007.18499.280016.0&scm_id=1007.18499.280016.0&scm-url=1007.18499.280016.0&pvid=af7d3c1d-897b-4dc9-94a0-e4d588fd6304&_t=gps-id:platformRecommendH5,scm-url:1007.18499.280016.0,pvid:af7d3c1d-897b-4dc9-94a0-e4d588fd6304,tpp_buckets:668%232846%238107%231934&pdp_npi=2%40dis%21USD%21%217.05%217.05%21%21%21%21%402103239c16562678005387784e07b9%2112000026528334512%21rec
