I installed a Bolton suspension front end, and had the same issue. i solved the problem elegantly and cheaply. Get some perforated square metal tubing, and cut a length about 3-4". You need to file the outside dimensions about 1/128 on all 4 sides to fit perfectly in the little detente where the kick stand base goes. Run the same diameter but longer stainless bolt through the frame and tubing, then center stand hole and install as usual, with the tubing as a spacer. Drill a self tapping screw on each side of the mounting plate to keep it from spinning, and it works perfectly. Paint and install!
