I tend to forget to unplug my battery charger. This $10 timer was the solution — set it for 1-6 hours depending on how much charge you need: BN-LINK 12 Hour Mechanical Accurate Countdown Tim...
Thanks for the info Dan, this is exactly what I was looking for. I just plug the chargers into my batteries, turn the dial to how many hours I want, and I'm done. I use a grounded three-outlet power tap so I can plug two things in at the same time without a power strip. One outlet of the power tap faces the wall in this position, but it leaves two open outlets.
If anyone else is interested, the full link is below
https://amzn.to/3c7xUPx
I use a smart plug into a power strip with the chargers plugged into that. Then use the countdown feature on the app.
https://amzn.to/3vJ58Nb
I also use a smart plug, but one attached to an Alexa. I named it "charger". Then I just say "Alexa, sleep timer 6 hours with charger".
Smart plug sounds like a great idea. Downside for me is when I travel with the bike.
