Pinstripes to accentuate the fender.
That's really nice! Freehand paint or decals? Either way looks classy.
Vinyl.
Those look nice! Where did you find them?
Quote from: papakins on May 03, 2021, 05:48:50 PM
eBay and Amazon. Search "pinstripe decals".
https://www.ebay.com/itm/133633031505
IDK, vinyl stipes are OK. You have to mark them out so they get put down straight. I decked mine out with reflective stickers, White on the front, Red on back. The set RPB sells is cool, works well, looks slick! They are only white. I have some NTSB stickers (probably from eBay) that I've used for lots of things. 1/2 red, 1/2 white. I'll see how well they stay. I did do a 91% alcohol prep everywhere. I also found some neat spoke reflectors, they do stand out!
See if you can see them in this photo. Good Luck to all. JLH
The stripes that I used have the narrow and wider stripe on a slightly wider clear tape that maintains separation between the stripes. The Rad Rover fenders have a crease at the edges. Pretty easy to align the clear down along the crease. Then you pull the clear off.
