Author Topic: Rad Wagon 4 Bottom Bracket needed Size & Source?  (Read 2189 times)
Buzz
« on: June 18, 2022, 08:06:12 AM »
Hi,
I would be happy if someone could let me know the size of the bottom bracket and where to buy it.
Several requests at the official support were of no help.  :-[
I just need a 1:1 replacement to eliminate the noise.
Thanks for your help in advance!
BR
Buzz
Ddaybc
  • Sr. Member
Re: Rad Wagon 4 Bottom Bracket needed Size & Source?
« Reply #1 on: June 18, 2022, 08:12:58 AM »
Do you mean where the crank and pedals are or is it something else?
Buzz
« Reply #2 on: June 19, 2022, 12:54:13 AM »
I mean the bearing/axis between the cranks.
The length is 154mm and unfortunately I can't find any bearing this size at google...
« Last Edit: June 19, 2022, 01:01:55 AM by Buzz »
Ddaybc
  • Sr. Member
« Reply #3 on: June 19, 2022, 10:10:41 AM »
I see the picture on your last post and it's what I would call a bottom bracket. It's actually an assembly and they do fit where the cranks and pedals are situated as the crank arms and pedals are attached to them. There are two types of bearings for them, caged and press fit bearings. I don't know what type the RW4 has. Removing and replacing caged bearings is not an issue but removing and replacing press fit bearings is more difficult. I also don't know how one would find out what size of bearings one needs as generally the bottom brackets are purchased as a complete unit.
FWIW I just measured the frame for the bottom bracket on my RW4 and it's 183 mm. It was with a tape and not a calliper so naturally I don't know how close it is but it's probably accurate within a mm or so. The actual bottom bracket will be smaller as they have to fit inside. However the measurement of the bottom bracket frame is how one normally orders them.
I hope this helps and if I'm wrong about what you are asking, I apologize.
Buzz
« Reply #4 on: June 20, 2022, 12:36:18 AM »
Hi, I?m searching exactly what you see on the picture but in the correct size. I can not find it anywhere with a 154mm length.
Im searching the complete bottom bracket as 1:1 replacement.
Thx for your help.
Radio Runner
  • Sr. Member
« Reply #5 on: June 20, 2022, 08:34:33 AM »
You need the shell length and the spindle length (that?s frame and axle)
However Rad uses odd ball proprietary sizes and replacements are only going to be available from Rad I?d imagine.
